V ValySk Reputable Nov 22, 2014 1 0 4,510 Nov 22, 2014 #1 How can I connect my printer (epson sx125) to my D-link router to use it wireless,I tried shareport an sx virtual link but none of them sees the router,they both say No device servers were found on the network.I use windows 8.1 x64. Thanks
Solution hang-the-9 Nov 24, 2014 That is not a network printer, if it will work your router depends on if your router has a print server capability. If it does not, you can get a USB printer server and attach that to the router like one of these http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007830%20600014444&IsNodeId=1&name=USB%202.0 You just need one of the cheaper $40 ones. Then install the printer as an IP printer and manually point it to the right drivers.
hang-the-9 Titan Mar 25, 2010 60,372 1,078 152,940 Nov 24, 2014 Solution #2 That is not a network printer, if it will work your router depends on if your router has a print server capability. If it does not, you can get a USB printer server and attach that to the router like one of these http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007830%20600014444&IsNodeId=1&name=USB%202.0 You just need one of the cheaper $40 ones. Then install the printer as an IP printer and manually point it to the right drivers. Upvote 0 Downvote Solution
