Need help. does my PSU support my future setup and are my fans able to cool everything correctly? ??
Anthony Mendez
104
Will this psu be enough to power all this plus OC the gpu as much as possible and slightly OC the cpu??? And also will the fan be enough to cool everything down? ??
CPU Intel Core i5-4670K 3.4GHz Quad-Core $229.99
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing $29.94
Motherboard Asus Z87-A ATX LGA1150 $134.99
Memory Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 $76.50
Storage Seagate Barracuda 1TB 3.5" 7200RPM $54.43
Video Card EVGA GeForce GTX 770 2GB Superclocked ACX $344.99
Case Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower $89.99
Power Supply Corsair 750W ATX12V / EPS12V $149.94
Operating System Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
http://pcpartpicker.com/user/NerroEx/saved/4kBv
Yes it should be fine but i would recommend the below option it is made by seasonic and fully modular and cheaper much better choice
for the money saved you could upgrade your cpu cooler to something like noctua nh-u14s would be much better heatsink
Oh and i run my gtx 670 with 500 watt PSU fine and its about the same as gtx 770 on power consumption
Power Supply: XFX ProSeries 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX US)
Total: $99.99
Total: $99.99
