Need help dvd not showing in bios
coolbreeze0121
24
As a lot of you know this is my first build and I am struggled. Got everything connected and installed started to do the bios and the dvd drive isn't showing up in the bios so I can load the operating system. The dvd turns on but not showing up in the listing in the bios. I am using a gigabyte ga z68x ud3h bs mobo with a gear head lighscribe 24 dvd sata drive. Also don't think the 8 gigs is showing in the bios either it looks like to me that it is showing only 4 gigs
coolbreeze0121
24
yes power is working and I have tried all of the SATA ports I will try adifferent cable. Anyone have any ideas I am stuck not able to do anything because I can't get an os onto my computer. Is there something in the BIOS that might be configured wrong?
