M Mazon1x Honorable Dec 24, 2013 20 0 10,510 Apr 10, 2016 #1 i have a 990fxa-ud5 r5 gigabyte board. and two evga gtx 570s ive tried everything possible. cant figure out how to enable these guys. Nvidia control panel only shows phys-x. both cards do show up and work fine. other than that.
Solution k1114 Apr 10, 2016 They need to be in the correct slots, the ones marked pciex16. The others that say pciex4 will not work. Also do you have the sli bridge connected?
M Mazon1x Honorable Dec 24, 2013 20 0 10,510 Apr 10, 2016 #2 Side not and or cross fire not sure which one it is nor the difference 🙁 Upvote 0 Downvote
k1114 Titan May 2, 2010 14,236 93 75,540 Apr 10, 2016 Solution #3 They need to be in the correct slots, the ones marked pciex16. The others that say pciex4 will not work. Also do you have the sli bridge connected? Upvote 0 Downvote Solution
M Mazon1x Honorable Dec 24, 2013 20 0 10,510 Apr 10, 2016 #4 can you pm me a picture of what slots they need to be in. im almost positive they are in the correct spots. and yes sir/ma'am the bridge is connected Upvote 0 Downvote
k1114 Titan May 2, 2010 14,236 93 75,540 Apr 10, 2016 #5 The slots are labeled, it's printed on the board. Upvote 0 Downvote
