FX-6300
Gigabyte 970A-UD3P motherboard (8+2 power phase)
Corsair H90 aio cooler
8gb DDR3-1866 RAM
Current BIOS settings (MIT>Frequency Settings)
Northbridge(FSB) 200
other northbridge(can't remember specific name): 2600
HT Link: 2600
CPU Frequency: 23.5 (4.7ghz)
CnC On
Turbo On (gigabyte restarts twice when its off, very annoying)
HPC On
APM Off
LLC Medium
Voltages (MIT>Voltage Settings)
CPU vCore: 1.25v
CPU vCore Offset: 0.1867-something(two ticks up from .175, two ticks down from .200)
Northbridge: 1.75v(directly under CPU vCore Offset)
Northbridge Offset: .175
NB Core(near the bottom): 1.2v
In HWMonitor I see the cpu voltage as 1.401ish volts. My temps are 45-50 C, quite good. Problem is, one of my cores keeps dying on Prime95, so it's unacceptably unstable. If I up the voltage to 1.428 or so, the temps jump up 5 degrees. 4.8 is impossible without pumping the voltage near 1.5, which I won't do because it puts the temps near 60 on water cooling.
Do y'all think I've hit my cpu's sweet spot at 4.6, or should I be ok with upping the voltage a bit? Or is the core dying due to something I'm not seeing?
8gb DDR3-1866 RAM
HT Link: 2600
CnC On
HPC On
APM Off
LLC Medium
CPU vCore: 1.25v
