I'm trying to get a better wireless connection in my basement. My modem/router is on my 2nd floor. Wireless speeds on 1st or 2nd floors are 100+ mpbs but drop down to 15 mpbs in the basement. I've got Xfinity/Comcast with the incoming cable going to the basement to a 6 way splitter (one cable going to each room with a coaxial jack - two go to TVs, one to the modem). I previously had FiOS so I've still got a wireless extender that I got from them. I tried going from the splitter (using one of the unused rooms connection) to the wireless extender. After I tried syncing the networks, none of them worked. I also tried doing ethernet over powerline but the connection is just as slow as the wireless.
Here are two options that I came up with but not sure which is best or if they would work.
1. Not sure I completely understand MoCA but since the extender is MoCA but the modem is not, I would need to put a MoCA adapter between the coax input and modem. Then I can put the extender into the splitter as I had previously done and the networks should combine. Or do I need another adapter between splitter and extender? I was thinking of the Actionteq WCB2000N. Not sure it would work or if I need something like the Actionteq ECB6200S02
2. I could install another modem/router to the splitter instead of a wireless extender (assume it would work since it would be just like the current set up: xfinity to splitter to modem/router). Issue would be the networks created would be completely separate. If this would work, I could use this opportunity to update my modem/router since its about 3 years old now.
If anyone has any input or directions, that would be great. I'm looking for something simple (unlikely that I install ethernet cables in the wall) and hopefully inexpensive. Sorry for the long post but I wanted to give whatever details you may need to help. Thank you in advance.
Current Modem: ARRIS SB6141
https://www.amazon.com/gp/product/B00AJHDZSI/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Current Router: TP Link AC1900
https://www.amazon.com/gp/product/B00PDLRHFW/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Current Wireless Extender: Actionteq WCB6200Q
https://www.amazon.com/Actiontec-80...reless+extender+action,electronics,147&sr=1-3
Prospective MoCA Adapter: Actionteq WCB2000N
https://www.amazon.com/Actiontec-Du...=moca+adapter&qid=1567727133&s=gateway&sr=8-6
Prospective MoCA Adapter: Actionteq ECB6200S02
https://www.amazon.com/Actiontec-Bo...G083T3MESSZ&psc=1&refRID=AT3BYESMJG083T3MESSZ
