Need Help Fast!!!!
Kryptic Gaming
42
Hello, i have recently purchased a computer and it is supposed to come in on the 13th and im trying to order some parts before it comes in. Im new to gaming on the PC and im new to PCs in general.. So i need some help finding out what parts i should upgrade on the PC. I plan on gaming and editing videos on it so i need pretty goo parts. IMPORTANT! I need most of the parts to be in the $50-$140 range. The computer is the CyberPower Gamer Ultra Gua 520. Yes i know that it isn't very good but its my beginner computer. Please do not just say i need a new GPU please tell me what kinds of parts and make sure they are compatible with my PC!
PC Specs-
Processor 3.8 GHz FX-4300
RAM 8 GB SDRAM DDR3
Hard Drive 1024 GB 1TB SATA III
Graphics Coprocessor Geforce
Card Description dedicated
Graphics Card Ram Size 2048 MB
Number of USB 2.0 Ports 8
Other Technical Details
Brand Name CyberpowerPC
Series Gamer Ultra
Item model number GUA520
Operating System Windows 10 Home
Item Weight 32 pounds
Product Dimensions 19.1 x 7.9 x 16.7 inches
Item Dimensions L x W x H 19.1 x 7.9 x 16.7 inches
Color Black/red
Processor Brand AMD
Processor Count 1
Computer Memory Type DDR3 SDRAM
Hard Drive Interface Serial ATA-600
Hard Drive Rotational Speed 7200 RPM
Optical Drive Type 24X DVD±RW Dual-Layer Super-Multi Drive
Audio-out Ports (#) 1
I need the parts to be between $50-$140 please!!
It's not the best you can do and goes a bit over $400 -
PCPartPicker part list: http://pcpartpicker.com/list/9zPK8K
Price breakdown by merchant: http://pcpartpicker.com/list/9zPK8K/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($94.99 @ Amazon)
Motherboard: ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard ($56.98 @ Newegg)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory ($27.99 @ Amazon)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive ($41.99 @ NCIX US)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card ($86.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($47.99 @ Micro Center)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply ($19.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89...
Without the exact model of your video card we can't tell if what you've got is enough for gaming.
RAM seems enough, the CPU could have been better but it will be just fine for most games. Would be good to also know which PSU your PC has. Everything else seems ok.
***System: AMD FX-4300 3.8GHz CPU | AMD 760G Chipset | 8GB DDR3 | 1TB HDD | Genuine Windows 10 Home 64-bit
Graphics: NVIDIA Geforce GT730 2GB Video Card
Does this help?
Can you help me find compatible parts? And ones that i can play games on and have good FPS. IF you could please keep the parts between $50-$140.
I see, a GT730, as anti-duck said, that won't be enough for games.
You'd need at least a GTX 750 Ti which is at 120$ at newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487025
With that mobo I guess the best "upgrade" for your CPU would be a FX-6300, will help in editing and in a lesser degree in games.
FX-6300: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286&cm_re=FX-6300-_-19-113-286-_-Product
However I'd suggest only spending on the video card. To be honest this idea of buying a pre-built computer and then upgrade it is not very good money-wise. It would have been better to build your own pc from scratch. But it is what it is, update the video card and you should be able to enjoy most games at mid settings.
A GTX 750 Ti would be a good upgrade and will be okay with the 500w stock no-name PSU. That's about it really with your budget.
I have to be honest, that system is not good and for ~$480, I'm sure someone on here could have put you a much better build together.
Thats the thing i held off on buying it, but im really new to building pc and i dont want to screw up on installing something.. Okay im trusting you guys, can you pick me out everything that i need for a great gaming PC but i need the cost to stay under 400$.
Well i havent purchased it yet, thats why im asking. Could you guys find me things to make a gaming pc that can play games wih good FPS and under 400$
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Total: $460.81
Generated by PCPartPicker 2016-06-11 16:35 EDT-0400
But you could save on the motherboard, the HDD, the video card, the case and the OS, I'm just really not familiar on where to shop in the US to get the best deals. Hopefully someone from the US will come in and put you a better build together within your budget.
That build anti-duck posted is great for its price. I doubt you could get a cheaper build. While you could save on the motherboard I advise against it, better to have a stable model than running later with issues, and for that price that mobo is really a bargain.
