Hi i am finally building a new pc and my old pc supports only 2 channel audio and im happy to finally upgrade to a board with 7.1 channel support. by the way since it supports 7.1 channel audio it should support 5.1 channel right? I need help figuring out if i can get 5.1 channel audio via Hdmi on these boards or do i need to plug in a toslink cable to get 5.1 channel audio to my home theater system? I want to know because the b350 board does not come with a toslink slot but the x370 does and hdmi or toslink is my only option right now of getting 5.1 channel. If i can get the 5.1 channel audio through hdmi on the b350 i would much rather buy the b350 because im going for a black/white color scheme and it costs less money. Thank you
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157761&cm_re=asrock_b350-_-13-157-761-_-Product
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157774&ignorebbr=1
