Need help figuring out if the video card will run with my PSU
TSN2k1
Commendable
Jun 12, 2016
What is my minimum system power supply?
I can't seem to figure it out, should I just add the wattage of all the rails or is there any other process?
PSU sticker -
http://imgur.com/6xoUwN7
I don't really know anything much about these PSUs. I wanted to know if it will atleast support a graphic card which requires 19W power supply and minimum system power supply requirement is listed as 300W.
Even though the sticker states it's continuous power output is 250W I'd never trust my life or my components for that matter on that unit as it's a mere ticking time bomb. Honest! If you'd like to learn a lesson the hard way, keep it with your system and after it takes down the system, you'll have to rebuild the entire build component by component.
You should follow this article to gauge your power requirements+some more for headroom and this PSU tier list to narrow down a reliable unit for your system. Can you pass on your full system's specs inclusive of your OS and connected peripherals?
