We have a HIK DVR setup at my shop with ISP A
The following ports are open and verified open via: https://www.yougetsignal.com/tools/open-ports/
http: 80
rtsp: 554
server: 8000
Using any app on our phones, we can connect and view the cameras no problem.
At home we try to connect using the same ISP provider as the shop, ISP A... via Internet Explorer, but we can NOT access the DVR. Luckily I have a second ISP, ISP B at the house as a backup... I connect the exact same laptop to ISP B and just refresh Internet Explorer, and it connects fine and I can see the cams.
I contacted ISP A to verify ports 80, 554, 8000 are not being blocked... they said they are not. Just in case, I went to www.grc.com and used the ShieldsUp to see if the ISP A was blocking the ports at my house... they came back as fine.
I thought that MAYBE the router I have for ISP A is causing the problem... I went to a neighbors place who has the same ISP A, but a totally different router.... and nope, he can't connect to my DVR IP either.
Anyone have any clue as to what the issue is?
Thanks all!
http: 80
rtsp: 554
server: 8000
Thanks all!
