I got an RT-AX3000 router but occasionally i get internet cutting briefly and then connecting it again. Can anyone help?
This is the log incase it helps with the issue.
Apr 20 13:42:58 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link DOWN.
Apr 20 13:43:07 WAN(0) Connection: Fail to connect with some issues.
Apr 20 13:43:17 WAN(0) Connection: WAN(0) link down.
Apr 20 13:43:27 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link Up at 1000 mbps full duplex
Apr 20 13:43:28 WAN(0) Connection: WAN(0) link up.
Apr 20 13:43:28 rc_service: wanduck 1422:notify_rc restart_wan_if 0
Apr 20 13:43:32 pppd[29866]: pppd 2.4.7 started by admin, uid 0
Apr 20 13:43:37 WAN(0) Connection: Fail to connect with some issues.
Apr 20 13:43:41 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link DOWN.
Apr 20 13:43:43 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link Up at 1000 mbps full duplex
Apr 20 13:43:53 zcip client: configured 169.254.16.97
Apr 20 13:43:57 dhcp client: bound 192.168.1.2/255.255.255.0 via 192.168.1.1 for 259200 seconds.
Apr 20 13:44:01 roamast: sta[66:7D:73:1F:77:BD] on ap[04:42:1A:60:E2:10], rcpi is 107 and rssi is -57
[Moderator edit to remove lengthy log entries.]
(Also..is there a way that I can just edit the log to make it that you can only scroll the log code in its own dialogue box and not scrolling on the actual post?)
