[Need Help] Files, Folders, Side Panel Libraries, Icon Missing
mrsmile
122
Files not showing up
No icon
Library panel not showing "document", "picture", "local disk", and other items
I've been getting the above issue as of lately. When I run "attrib -h -r -s /s /d c:\*.* the abovementioned problem goes away but after a while I would have them again. If I restart window explorer, the same thing happens: the problem goes away but after a while it comes back.
from your file manager (which isnt showing you any files)
view tab >
options button on the right side > opens new box Folder Options
view tab > restore default settings
select show hidden files
un-select show icons instead of thumbnails
apply.
Should your thumbnail cache be corrupt > follow this sites instructions
https://www.windowscentral.com/how-reset-thumbnail-cache-windows-10
I hope that solves your issue. (just check your active programs, maybe one of them is trying to force you into window for dummies mode - eg everything turned off kid friendly).
Adding folders to your library should be done from the library box >
right click library folder >
select restore default libraries
if the libraries you want are not included...
view tab >
apply.
if the libraries you want are not included in the restore, you must add them by>
open the library name and select add location >
navigate to location of library folders you wish to add to master library.
eg pictures libaray is restored, but no pictures = open pictures library > add location > navigate through your HDD to where your pictures are located.
