Need help find a graphics card for HP Pavilion 510-p026 Desktop PC
ThunderCloud1980
Commendable
Nov 22, 2016
Hello I am new to this forum and came here with a very specific issue I need addressed before the holidays. For Christmas I am getting a new HP Pavilion tower that has 1tb hard drive 12 gigs of ram but has a intel I5 processor and intel HD 530 Graphics graphics card. My objective is to find a graphics card that can fit this machine and allow Me to easily play on second life as its a graphics heavy program but i was wondering if there is a low budget graphics card that can get it done and fit this tower Thanks in advance for the help
For reference I have attached the pc i am getting pavilion
PC building is like Lego. nothing to it. Youtube vids and Forums basically WALK you through it.
The pavilion is build on CHEAPEST parts available.
You are not even getting a TRUE i5-6400..... it's a 6400"T". that's a 2.2Ghz vs a normal 2.7Ghz.
and then you will spend MORE money into buying a GPU?
Take the hard advice to swallow. Return it. Buy yourself components and walk yourself through it. You will get a MUCH MUCH MUCH better system for LESS LESS LESS retail value.
Let's take your Pavilion for example. It's 580$. and then you will drop a GPU in there... likely a GTX1050TI or even a GTX1060 3gb, which will boost the price by ... roughly... 180$ (1050ti bit cheaper, 1060 a bit more expensive)
that would make for a grand total...
main question is.. WHY?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($190.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($41.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($74.99 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive ($60.99 @ Newegg)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card ($129.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($39.89 @ OutletPC)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply ($29.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($79.89 @ OutletPC)
Total: $648.62
Generated by PCPartPicker 2016-11-22 20:53 EST-0500
this here is a way better PC
it could be better, but just a quick THROW TOGETHER for price view
The reason why honestly is price plus Im not a pc builder plus I already got this one ordered from staples
that would make for a grand total of a 760$ system. or if I may, 800$.
and even this, could be squeezed out into i5-6600k (with a cheaper mobo, but it's difficult to choose correct low budget z170)
Motherboard: MSI B150M MORTAR Micro ATX LGA1151 Motherboard ($64.99 @ Newegg)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory ($69.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1060 3GB 3GB Windforce OC Video Card ($199.99 @ B&H)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply ($34.99 @ Newegg)
Total: $751.82
Generated by PCPartPicker 2016-11-22 21:23 EST-0500
Prebuilt system are crap. There is virtually NO upgrade path from them. they are lowest of the low.
