Current one have to speak directly into it, need something that can sit on the desk and still clearly pick up voice from different directions. Budget is <$25; is for child so better if it picks up higher end (treble?)
I haven't noticed any echoing on that mic either.I got the Jounivo (JV-601)
That one looks pretty good. Is there any advantage to using USB over 3.5mm input? Will be used with older Dell XPS Studio that has fairly decent integrated THX TruStudio.Take a look at this mic. I was surprised at how well it picked up my voice. It sits to the right of me about 16" away.
https://www.amazon.com/dp/B07N2WRHMY?ref=nb_sb_ss_w_as-reorder-t1_ypp_rep_k9_1_6&&crid=6KBYPX84LF6Y&&sprefix=jouniv
I can't answer that question.That one looks pretty good. Is there any advantage to using USB over 3.5mm input? Will be used with older Dell XPS Studio that has fairly decent integrated THX TruStudio.
Ok that's a pretty good comparison for referenceI can't answer that question.
I also have a Blue Yeti mic ($100!) on my other PC which is a great microphone.
The Jounivo was almost as good as that Blue Yeti microphone and both mics are off to the side of my monitors.
I just got the mic and there's a kinda chamber/almost echo sound on receiving end; using headphones; did you notice that? Previous mic was 3.5 jack & unidirectional; don't know if either of these made a difference.Ok that's a pretty good comparison for reference![]()
Are you saying you got a Blue Yeti mic?I just got the mic and there's a kinda chamber/almost echo sound on receiving end; using headphones; did you notice that? Previous mic was 3.5 jack & unidirectional; don't know if either of these made a difference.
I got the Jounivo (JV-601)Are you saying you got a Blue Yeti mic?
If so, check the setting on the Gain button on the back and there's 4 different settings you can set the mic to depending on the surroundings you're in and how you're using it.
I've never had an echo sound when using mine but I'm simple, once I found the settings that worked best for my situation and how I used it, I left it alone and didn't change anything else.
It's fine now, just a lot more powerful than the last one was, had to get used to it. Good mic, thanks for the recommendationI haven't noticed any echoing on that mic either.
It could be where it's placed or how close it is to you.
Mine is off to the right about 16" from me and slightly in front of me.
