Need help finding a budget motherboard
davezzzz6
50
Need help picking an ATX motherboard around 60-80 pounds or dollars (I'm on a tight budget) for an i7 6700 non k that supports DDR4 ram at 2133mhz
I have seen the FaQ section of Amazon. The questions seem to be answered by Amazon customers.
If you still doubt the compatibility, you can look for it on asus official website.
From my understanding, it supports ddr4, but only up to 2133mhz.
Thank you, I actually have a question I'm doing some research currently and I've come across this motherboard randomly https://www.scan.co.uk/products/asus-h170-pro-intel-h170-s-1151-ddr4-satae-m2-(pcie-sata)-2-way-crossfire-realtek-lan-usb-c-(5gbps)- and it says it supports DDR4 ram however when I checked it on Amazon https://www.amazon.co.uk/Asus-H170-PRO-Motherboard-Socket-Express/dp/B012AWVWGQ in the FaQ section someone states only DDR3 is supported, im very confused
Can't remember how to reply to people directly on this lol but thank you, I investigated the motherboard on the official website and they state it's DDR4 compatible, thank you once again for your help could you just check really quickly to see if it is compatible https://www.asus.com/ie/Motherboards/H170-PRO/specifications/ just want to be sure
