Question I need help finding a good used Xeon for under $100 ?
litaidd
120
Does anyone know a good platform/xeon cpu that I could get with high core count maybe 12-16+ physical cores if possible, doesn't need to be ecc, and not looking for anything new obv for the price.
I have a 32gb kit of ddr3 and a 32gb kit of ddr4 so it can be from either of those generations. Just looking for a cpu recommendations and then I'll go hunting for a used motherboard. My budget is probably about $100 on the cpu, and it will be used to run some servers through vSphere, and some lighter gaming services. I'd like one that works on an lga 2011, 2011-v3, or 2066 socket.
Lutfij
You would need to specify what motherboard you have for us to narrow down suggestions.
Just a quick search for LGA2011 lands me to this shortlist;
and I come to this processor;
https://www.intel.com/content/www/u...99a-v4-55m-cache-2-40-ghz/specifications.html
and they are around the same price range;
https://www.ebay.com/b/Intel-Comput...or-Model-Processors-22-Cores/164/bn_110578939
but this will change with respect to your motherboard's socket.
