Need help finding a motherboard for chosen CPU and GPU
alekumpel
5
Hello, I'm trying to choose a motherboard for the following CPU and GPU, which I am going to order along with the motherboard:
Intel Core i5-3570K
MSI GeForce GTX 760 2GB
I will choose the RAM and the rest after I choose a motherboard.
Does anyone have any recommendations as to which motherboard to buy? I was looking at the ASRock Z77 Extreme4, but I'm not sure.
Edit: I should note that I do plan to overclock the CPU.
Stick with your choice of the Ex 4, best mobo of the Z77s, would switch the 760 to the Asus CU model, better cooling and OCing and if not looking to OC at all may want to stick with a DRAM set of 1866/9 as tops, would suggest the Snipers, great sticks
