Need help finding a network adapter
Noah M
225
Hello! I am looking to get a wireless network adapter for a PC that I am going to build soon. All of the ones that I find come with a CD to install something. Are their any wireless network adapters that do not come with a CD but with perhaps a flash drive or something else to install their software? Mabye some don’t even need an installation. If you could help me find one of these cards for under $30 that would be great, if not, a little over is fine as well. Thanks!
You are going to have possible problems installing your motherboard drivers without an optical drive. You will have to go to the manufacturer's website on a different computer and download to a flash drive. You can do the same with the WIFI card.
