1. What is your budget?
£600-850 or about $806 - $1054
2. What is the size of the notebook that you are considering?
13' or 15' - preferably 15'
3. What screen resolution do you want?
On the higher end. Bad eyesight even with glasses and will be using it quite a bit for GIMP/Photoshop to tinker with my artwork. So a good display/vibrance is important. Full HD display.
4. Do you need a portable or desktop replacement laptop?
Laptop replacement.
5. How much battery life do you need?
Not super important. Will mostly be using it at home, where it can remain plugged in.
6. Do you want to play games with your laptop? If so then please list the games that you want to with the settings that you want for these games. (Low,Medium or High)?
Yes, but mostly Blizzard games like Hearthstone/Diablo 3 etc. But also games like Skyrim on Medium+
7. What other tasks do you want to do with your laptop? (Photo/Video editing, Etc.)
GIMP/Photoshop
8. How much storage (Hard Drive capacity) do you need?
500GB+ SSD + HDD (Preferably SSD, but not absolutely necessary)
9. If you are considering specific sites to buy from, please post their links.
Mainly Amazon.co.uk atm, but the prices seem to be dreadful at the moment.
10. How long do you want to keep your laptop?
2+ Years
11. What kind of Optical drive do you need? DVD ROM/Writer,Bluray ROM/Writer,Etc ?
Not necessary. DVD Drive optional
12. Please tell us about the brands that you prefer to buy from them and the brands that you don't like and explain the reasons.
No preference.
13. What country do you live in?
UK
14. Please tell us any additional information if needed.
I will likely only have a year in the UK where I can physically get it repaired from any local dealer. After that USA. I've had my eye on this one for a while https://www.amazon.co.uk/gp/product/B01HIWOOWM/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE but it has some bad reviews? And it seems a bit pricey for what it can do. Is there a better alternative? Should I try to wait until I can buy one in the USA? How much more expensive will it be to buy one now? Right now my laptop barely works and has to be plugged in at all times. And household needs another PC/laptop of some sort for the next year.
Thank you so much for the help! It's been a while since I've bought a new pc/laptop and I am so out of the loop. Really appreciate the help
Laptop replacement.
GIMP/Photoshop
2+ Years
No preference.
UK
