Hello everyone
I'm looking for a certain case that you can recommend. I need one that can mount this motherboard: Gigabyte Z97X-Gaming 5 Intel LGA1150 Z97 ATX Motherboard.
and in the same time can well fit this GPU : MSI NVIDIA GTX 980 Gaming Graphics Card. and it has good airflow and Cable management.
I dont care much about the Design as long as it covers my needs.
Thank you !!
Edit: will this case work ?
Cooler Master CM Storm Stryker XL-ATX Case
http://www.amazon.co.uk/Cooler-Master-Storm-Stryker-XL-ATX/dp/B0083XVWSA/ref=sr_1_1?ie=UTF8&qid=1425179435&sr=8-1&keywords=Cooler+Master+Storm+Stryker+Case
Thank you !!
