Need help finding a PSU compatible with my MOBO.
Sep 15, 2018
Can someone find me a 600-700W PSU that will be compatible with my motherboard, I have a old motherboard and I was gonna drop all my specs in pcpartpicker and see if it would work but my motherboard doesn't even show up on pcp. Anyways my motherboard is Hewlett-Packard 304Bh (XU1 PROCESSOR).
From what I read you may want to add the GPU into your HP PC.
So
1) Can you post what GPU you want? if you want to add the GPU.
2) Where do you shop the PSU?
3) What budget do you have?
4) Check your MB to see it had the newer version BIOS or not, also try to find the BIOS download from HP, in case you need it.
And before you buy the PSU and GPU, try this first: borrow one, or if you have one GPU, then try to use the GPU to see you can boot the PC or not, also make sure the GPU will fit into your HP PC too.
HP Desktop PCs - Computer Does not Start After Installing a Video https://support.hp.com/us-en/document/c03653200
So
