[SOLVED] need help finding a upgrade
Sep 6, 2020
4
Lenovo H530 Desktop
Machine type: 10130
MTM: 57324189
Windows 10 Home 64bit
Intel Pentium G3220 Dual Core @ 3ghz
Lenovo Sharkbay NOK Mainboard
I want to upgrade this cpu but cant find one that is compatible and theres nothing about it online
It comes with your existing CPU,i3-4130,i5-4400 and a i7-4770.
With OEM pc's its best to buy a CPU that already comes with certain version of your computer's,because they all have the same mobo,and its the least risky type of upgrade.Of course i would suggest you tu buy a i7-4770,but if that is out of your budget,the i5-4400 is the option i would go for.I would avoid the i3 since it has only 2 cores
Example:I had a lenovo thinkcentre edge 72 with i3-3240,upgraded to a i5-3570,because its on the list of the cpu's that come with that tipe of computer:https://support.lenovo.com/rs/en/solutions/pd024645
Adding onto what @Djoza said, look for a used CPU. You may not even be able to find one new and if you do, it will most likely be of terrible value. When buying a used CPU, try to get one that hasn't been significantly overclocking by the original user and has been kept below 80 C at all times. Obviously, your going to just have to hope the original owner is being honest. Buying used is a very good thing to do from an environmental standpoint. An old i7 will outperform new pentiums, so the fact that companies still make these super low end CPUs is just a waste of materials and of manpower.
i7-4770 still holds ground on the i3-10100
So you're saying that I should get one that is in the other versions of this or what didn't understand that
That is what he's saying, since they should have same motherboard and same PSU. Also, certain manufacturers make their boards only compatible with certain RAM, CPU and more, to try to limit upgrade options. A CPU that the motherboard already can clearly take are the safest picks.
Thanks a lot guys
