Need help finding an mATX case
Yasuh
5
Is there any small mATX with decent cable management, thermals, acoustics and a small size fitting some rx 580? A good price would be great too.
Coolermaster N200 but there are more expensive options out there. Fractal and Corsair make a couple but in terms of front panel connectivity and where you're located, they may be limited.
Speaking of which where are you located and what sort of a budget have you set aside for the N200?
I live in finland and I should be able to reach all the shops here. It would preferably be under a 100€ I will check if I can find that case in here.
That does look pretty good. I'll have to check if that is alright to transport. This would be for my brother and I have a corsair spec-01 for size comparasion. (Preferably smaller than that)
