for118 :
i recently bought a GTX 960 ssc and a logisys 480W PSU, but i did not realize the card required a 8 pin plug in from the PSU. i know there are 4 to 8 pin adapters but im not sure which one would be compatible or not, any help would be appreciated.
+1
the card should have a dual 6-pin to single 8-pin adapter, use this
if your power supply does not have two 6-pin pcie cables
then you need to get a proper power supply that does
that is a very low quality brand psu you have, you should avoid adapters of any other kind
