Need help finding decent PSU for an r9 380
MYG2580
4
For a budget build with:
AMD Fx-6300
Gigabyte ga-970 d3p
Asus strix r9 380 4gb
I need help finding a suitable power supply that is not too expensive. The main place where I will be buying all my stuff is http://www.msy.com.au/24-power-supply (living in Australia). I have considered the EVGA 600B, XFX ts 550W and the seasonic s12 however the shipping costs for these are way too high. is an antec vp-600p sufficient, or is there any other PSU that is not too expensive (under $90) that I should consider. Thanks
This would be plenty sufficient for under $46 total:
http://www.newegg.com/Product/Product.aspx?Item=9SIA1N83U90965&cm_re=evga_500_B1-_-17-438-012-_-Product
Recommended total sys power for a 380 is 500w 28 amps.
"Radeon R9-380 - 28A and a 500W psu minimum"
Source: https://forum-en.msi.com/faq/article/power-requirements-for-graphics-cards
The EVGA 500 B1 is 500w, 40 amp rated.
"Output +3.3V@24A, +5V@20A, +12V@40A, +5VSB@3A, -12V@0.3A"
Source (Specifications tab): http://www.newegg.com/Product/Product.aspx?Item=9SIA1N83U90965&cm_re=evga_500_b1-_-17-438-012-_-Product
