Need help finding laptop for a 6yr old, $250 or under.
budmonster
52
My 6yr old son is pretty tech savvy & has been asking for a laptop. I'm looking for something $250 or under, it can be refurbished.
He will be doing school stuff on it, learning software & light gaming like Minecraft.
This is the laptop I purchased: http://www.newegg.com/Product/Product.aspx?Item=1TS-000D-002J8
but was told it will not be "sufficient" enough for a young kid so I'm thinking of returning it. Can you guys please help me find one that'll work for him, however I can't justify dropping $500-600 on a 6yr old.
If you are a bit handy:
Buy a refurbished thinkpad. Here is one for $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16834321062
Buy a Samsung 120gb ssd for about $70(240gb will be about $100)
clone the os and replace the hard drive. You may need a usb to sata adapter cable for $10 or so.
The performance difference is magical.
2gb is a bit small, but a 2gb ram upgrade will be about $15.
So, for $200 or so, you will get a very good quality laptop that should last a long time.
Latest posts
