Hello,
Firstly I'd like to say I'm based in the UK so I probably buy it off ebay as the prices are cheaper there then most online stores anyway. So here's my problem;
I have an really old desktop here and not a lot of money. The desktop is a Dimension 2400 Dell PC, these are the basic specs:
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html
The only difference is the ram is 256 ram which I will upgrade to 4 gig soon.
The only thing I have changed to the computer are that I've changed bother the Drives and upgraded them to DL burner and DVD reader.
The processor is a Intel Pentium 4 CPU with 2.4GHz and the graphics card is some random crap one called Intel 82845G Graphics Controller and I'm running on Windows XP 2002 Professional Service Pack 3.
I've been running on this computer for quite some time and I can't even play games such as half life 2 or counter strike in low specs and I get computer freezes watching HD videos online and off.
Anyway I've been researching quite a bit on graphics card and that, I'm a bit poor at the moment so I can't get the best graphics card out on the market today I just need a good graphics card that will play the latest games such as crysis at the average specs, I don't need full blown highest specs as my monitor is only about 16 inch lcd and quite old so I probablly won't notice the difference. Money is quite a big factor here on deciding what graphics card I will get so any advice is helpful. Also do I need to upgrade my processor at all or is that fine. Lastly when I look at some prices for RAM for some reason the lower speed rams are higher priced then the slower ones even though there all 4gb, for example:
http://stores.shop.ebay.co.uk/koybe-inc__W0QQ_sidZ794752399?_nkw=4gb&submit=Search
Anyway to sum up, I would appreciate advice on what graphics card I should get, if I need to upgrade my processor or anything else (I don't care about the sound if it's in hd/surround etc) and the question about the ram and if you could point me to which ram I should buy out of those in the link I posted.
Thank You,
-3dluis
Thank You,
-3dluis
