Need help finding the right laptop
bluebird123
I'm looking for something with:
-a dedicated graphics card
-an i5 or i7 processor
-less than 15 inches
-less than 6lbs
-no Apple products
-budget: less than $1500
Is there anything with all/most of those specs?
I found a few that I am interested in,
-lenovo thinkpad x1 carbon
-ASUS U31SD-DH31 Ultrabook
-lenovo thinkpad X1 129126U
Also, the perfect laptop for me would be the lenovo ideapad y580 BUT i prefer less than 15"....is there anything with the same specs as this one but with a smaller screen size?
-It's ok, but doesn't have a dedicated graphics card so if you wanted to play games on it, I'd pass on this one.
-Not a bad choice but the dedicated graphics card could be better and also not a fan of the Intel Core i3 if you will be gaming
-Nice to see the i5 but it does not have dedicated graphics.
Found a 14" ASUS laptop with a 660M (same as Y580) and an i7 CPU:
This is pretty much exactly what you are looking for!!!
http://www.bestbuy.com/site/Asus---14%26%2334%3B-Laptop---8GB-Memory---750GB-Hard-Drive---Black/6775259.p?id=1218806576744&skuId=6775259
Why no high performance in small, light packages?
If you have a fast CPU and/or GPU they need to be cooled which requires a fan and heat sync. Both the fan and heatsync take up space and add additional weight to a laptop. That is why the fastest laptops money can buy require lots of cooling and are heavy/big.
Ultrabooks are super thin and light generally they are also much slower than a full size laptop. Which means they are less than ultra and the name "ultrabook" is an oxymoron. Perhaps thinbook would make more sense.
Getting more for your money:
Generally the most commonly purchased laptop screen size is about 14" - 15" and because of that this screen size is mass produced and many times laptops that are bigger or smaller can have a higher price even when the specs are the same or similar.
