[SOLVED] need help finding what Graphics Card i can upgrade to
Jul 30, 2020
11
hey im just wondering what Graphics Card i can upgrade to from my old one
i dont no alot about pc's but this is what i'v got
windows 10
predator g3-605
intel core i7 processor 4770
nvdia geforce gtx 645 2gb
12gb ddr3 memory
power supply 300w
Jul 30, 2020
11
Whats ur budget? And what do you plan to do with it?
hi jim i was looking more at a $400 graphics card and needed it for just better performance gaming, i was in a bit of a rush but i've just got a new inno3d geforce gtx 1060 3gb 192bit gddr5 so my main question do you think that's ok to go in my pc?
Ziadul87
Respectable
Sep 7, 2019
588
62
2,190
53
IF you were looking at 400$, why bought 1060 3gb? Or do you plan on upgrading again?
Jmi20
368
87
790
13
Though the others are correct, I have used a GPU that required a higher power than my PSU could provide to no noticeable ill effect. Though I am not condoning it.
A 1050 would have been a safer bet...
Jmi20
368
87
790
13
damn really i think i'll just build a new one lol
To be more specific on what I said, I have tried running a Gtx 750ti which requires 300w on a 200 ish watts psu before.
When looking at gpu specs, there are two power specs, one for the demand of the gpu, another for the minimum recommended power requirement.
In the case of the gtx 750ti, the first spec (listed as graphics card power in nvidia site) is only 60 watts, so it could be run even without the 300w power requirement.
Don’t quote me on this but the way I understand it is the minimum power requirement accounts for all other components in the system including the gpu, not just the gpu in itself.
Ziadul87
Respectable
Sep 7, 2019
588
62
2,190
53
That wasn't the point. I had a 400W PSU with 192 W on 12V rails. Even 1650 was enough to shut it down.
Without knowing his PSU model, you can't say for sure it's actually 300W. And even if it is 300W, keeping it under load at all times isn't ideal let alone safe.
Jmi20
368
87
790
13
I understand, thats why I said on my first post that I don’t condone it... was just elaborating. What I'm trying to say is it could be done in some cases, but it shouldn’t.
Jul 30, 2020
11
Nope, that gpu requires at least a 450w psu.
hey just wondering if you think this is all compatible
inno3d geforce gtx 1060 3gb 192 bit gddr5
Gigabyte Z390 Gaming X ATX LGA1151 Motherboard
Corsair RM550x 550W V2 Power Supply Fully Modular 80 Plus Gold
Intel Core i5 9600KF 6 Core LGA 1151 up to 4.6GHz CPU Processor
Corsair 16GB (2x8GB) Vengeance LPX 3200MHz DDR4 RAM - Black
Silicon Power 256GB SSD 3D NAND A55 SLC Cache Performance Boost SATA III 2.5" 7mm (0.28")
Microsoft Windows 10 Home 64bit
Seagate Barracuda 2TB 3.5in SATA3 256MB Cache Hard Drive
if there is somthing im missing or somthing in here that cant work with whats here it be awesome if you can let me no
Ziadul87
Respectable
Sep 7, 2019
588
62
2,190
53
The first thing I'd remove from this would be the GTX1060 . 3GB? Seriously? Even at 1080p some games require more than 4GB. How much are you getting the 1060 for? There might be obvious better choice than that.
Jul 30, 2020
11
i've been sitting here for like 30 mins waiting for a reply and my dumb ass didnt refresh to that you guys have been replying the whole time lol
Jul 30, 2020
11
thing is i already got the 1060 today and got it for $360 au dollers lol
poorbugger
655
86
11,090
95
Are you on a budget? If you are, tell me your budget and ill come up with a better list if needed
