So, I finally decided to build a new gaming PC. My budget at the moment is $1000, and there are two builds I am debating on to chose from. If you have a better build for around $1000 please let me know! Thanks!
P.S. Most of these pieces are on sale, so I listed the sale prices.
Build #1
Intel Core i5-4670K CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899 ($235)
Cooler Master Hyper 212 EVO CPU Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 ($35)
MSI Z87-G43 Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130694 ($180 on Amazon)
Sapphire Radeon HD 7950 Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202071&cm_re=Sapphire_Radeon_HD_7950_Graphics_Card-_-14-202-071-_-Product ($200)
8GB Corsair Vengeance DDR3 RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233170 ($90)
120GB Samsung 840 EVO SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147247 ($85)
1TB Western Digital WD Blue Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339&cm_re=1tb_Hard_Drive-_-22-236-339-_-Product ($55)
600W Corsair CX600 PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028 ($70)
Corsair 200R Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018 ($50)
Total for Build #1: $1000
Build #2
AMD FX-8350 8 Core 4.0GHZ: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284&cm_re=AMD_FX-8350-_-19-113-284-_-Product ($150)
ASRock 970: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157394&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= ($95)
16BG G.SKILL Ripjaw: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568 ($155)
1TB Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= ($50)
Toshiba 128GB SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820168088&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= ($80)
EVGA GTX 760 2GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130932&cm_re=GTX_760-_-14-130-932-_-Product ($210)
Fractal Design Define R4: http://www.newegg.com/Product/Product.aspx?Item=N82E16811352021&cm_re=Fractal_Design_Define_R4_with_Window-_-11-352-021-_-Product ($110)
620W Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= ($65)
Total for Build #2: $915
Build #1
Build #2
