[SOLVED] Need help for 1070
Jun 25, 2020
hello ! im trying to buy an used EVGA 1070 Ti hybrid . and i wanted to ask if there is any common problems with water cooled graphic cards or any other thing that i need to know if something goes wrong
Not really, and EVGA is one of the best in terms of quality so you should be fine. Just dont spend alot extra for the water cooling factor since in reality a good air cooled car will perform the same.
