Need help for $700-$800 i5-2500k from scratch
denzel562
8
Approximate Purchase Date: Around the end of July or the beginning of august
Budget Range: $700-$800
System Usage from Most to Least Important: everyday gaming, watching movies, surfing the internet)
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts:newegg.com
Country of Origin: U.S
Parts Preferences: I would like to use an Intel i5-2500k CPU
Overclocking:Yes
SLI or Crossfire: In the future
Monitor Resolution: (e.g.: 1024x768, 1280x1024, 1440x900, 1600x1200, 1680x1050, 1920x1080, 1920x1200)
Additional Comments:First time building pc so im kinda bad at this, but would like to get 6-8 gbs of ram if possible not mandatory , but i would mostly want a build that can play games like Global Agenda, Starcraft 2, WoW, and League of Legends on max settings.Wont mind if i have to turn it down a notch or two.
heres how id do it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.689147
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=f3%201tb
if you need to stick with the budget:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.683241
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948&cm_re=6870-_-14-102-948-_-Product
if you can break it:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.662487
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
genghiskron
1,115
heres how id do it:
With your budget and what your looking for...don't limit all your shopping to newegg or your going to get hosed.
This build allows you to add another one of those factory over clocked gtx 560's later on for SLI.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.683239 $254.98
Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 120mm Fan, 1x Rear 120mm Fan
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.superbiiz.com/detail.php?name=MB-68MA2B3&title=GIGABYTE-GA-Z68MA-D2H-B3-Socket-1155-Intel-Z68-DDR3-2-Way-SLI-CrossFireX-SATA3-USB3-0-A-GbE-MATX-Motherboard $119.99 Free Shipping
GIGABYTE GA-Z68MA-D2H-B3 Socket 1155/ Intel Z68/ DDR3/ 2-Way SLI & CrossFireX/ SATA3&USB3.0/ A&GbE/ MATX Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231427 $43.99 FREE SHIPPING $9 off w/ promo code EMCKCJH37, ends 7/18
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049 $94.99 - $69.99 after mail-in rebate FREE SHIPPING
Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697 $59.99 FREE SHIPPING $10 off w/ promo code EMCKCKC22, ends 7/13
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039 $18.99 FREE SHIPPING
Sony Optiarc CD/DVD Burner 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model AD-7260S-0B - OEM
http://www.superbiiz.com/detail.php?name=EV-560_1G&title=EVGA-nVidia-GeForce-GTX560-1GB-DDR5-2DVI-Mini-HDMI-PCI-Express-Video-Card $$188.99 + $2.98Shipping
Total: $781.92 *not including mail in rebates
genghiskron
1,115
gotta disagree with ya why_me, as my aforementioned build comes in at $784 before rebates. not exactly getting hosed. comes with an arguably better mobo and 4gb more ram too. you could argue that the gtx560 is better than the 6870, fine, my build would then total $799 and still has a better mobo and 4gb more ram, all from the delicious egg.
Agreed. I didn't see your post until I posted after I hit the "Submit" button.
