need help for a new mobo
XxFri3ndlyxX
Hey guys i need some help. Hopefully someone has the anwser. So right now i have a amd a10 6800k 4core a stick of ram of 8 gb @ 2400mhz the pc runs good but i want to upgrade to fx8350 but the thing is i dontknow which motherboard would take my ram. Anyone has any idea suggestion on which one i should get. The reason i dont go intel is im on a tight budget so fx 8350 is the way to go. My budget is max 500$ for the cpu and motherboard altogether. Thanks for the help.
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($167.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($27.98 @ OutletPC)...
Motherboard: ASRock 990FX Extreme9 ATX AM3+ Motherboard ($166.30 @ Newegg)
Total: $352.27
Generated by PCPartPicker 2015-06-04 11:23 EDT-0400
The quality motherboard can support your RAM easily:
- 4 x DDR3 DIMM slots
- Supports DDR3 2450(OC)/2100(OC)/1600*/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 64GB*
- Supports Intel® Extreme Memory Profile (XMP) 1.3 / 1.2
- Supports AMD Memory Profile (AMP)
Since you're willing to spend up to $500, can go liquid cooler. Config with liquid cooler:
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($97.49 @ Newegg)
Total: $421.78
Generated by PCPartPicker 2015-06-04 11:26 EDT-0400
Cheers!
