Hey There,
I am pretty noobish around Wireless stuff so decided to ask around. I have a WiFi speed of roughly 980 mbps down and 880 up. However, the router and modem are in a room away, and I cannot run an ethernet cable across. There are a lot of walls around so the WiFi connection gets pretty weak too.
So I was looking for a Wireless Extender that will help me keep a good speed. I am happy with a speed of 100 to 200 mbps too even if it means that the speed has been reduced but is constant.
AFAIK, there is something called a Powerline adapter, which I think is a sort of WiFi Extender? If so, could you recommend one with a maximum speed of 1 gbps or above, or give an alternate option? Main usage will be for gaming and stuff.
