Need Help for Budget Build
Alexis92
330
Hey guys, i need help my budget is $1050 for a gaming PC i would like the AMD 390 card with 8 GB because i do hate that 3.5 GB fiasco from Nvidia.
only problem is i cannot buy from Newegg, NCIX , Amazon like Americans do i'm in the Philippines and there's only 1 website i can trust, and buy from.
http://dynaquestpc.com/ ( In Philippine Pesos my budget is P50,000 ) i would like a build that can max out games like GTA V , ArmA 3 etc.. mostly Multiplayer games, but i'm not expecting the best of the best.
Thanks.
CPU: Intel i5-6500 - 9,500
MOBO: MSI H170M PRO-VDH - 5,750
RAM : GSkill Ripjaws V 8GB Dual DDR4 2400 (F4-2400C15D-8GVR) - 2,700
PSU: Corsair CS750M 750W 80+ Gold Modular Power Supply - 5,000
CASE: NZXT Source 340 (S340) - 3,500
GPU: Sapphire R9-390X Triple Tri-X OC 8GB Gddr5 512bit - 21,500
Total, around 47 000
Pretty much best you could get.
i mean a complete build with HDD, fans, cooler etc..
CPU: i5-6500 (P9500)
GPU: Sapphire NITRO R9-390 Tri-X OC 8GB Gddr5 512Bit (P16000)
Mobo: Gigabyte GA-H170M-D3H (P5750)
RAM: 2 4GB HyperX Fury DDR3 1866mhz (P2500)
PSU: Seasonic M12II-750 EVO 750W 80Plus Bronze (P4500)
CASE: Tecware Infinity (P1300)
CPU Cooler: CM Hyper 212x (P1900)
HDD: Seagate 1TB 7200rpm (P2500)
CASE FAN:4 Deepcool 120mm XFan (P520)
Total = P 44,470
Rest of the cash can be spent at the games you want.
Or get a Sapphire R9-390X Triple Tri-X OC 8GB Gddr5 512bit (P21500)
isn't the ram incompatible with the mobo?
CPU: i5-6500 (P10000)
GPU: Asus Strix GTX970 4GB (P15000)
Mobo: Gigabyte GA-H170M-D3H (P5800)
RAM: Kingston HyperX Fury 8GB DDR4 2133mhz (P3000)
PSU: Seasonic M12II-750 EVO 620w 80Plus Bronze (P3500)
CASE: Cooler Master Pro5 (P4600)
CPU Cooler: CM Hyper 212x (P2000)
HDD: WD Caviar Blue 1TB 7200RPM (P2500)
SSD: Samsung 850 Evo 500GB (P3000)
CASE FAN:4 Deepcool 120mm XFan (P600)
Total = P 50,000
sadly i prefer the r9 390 because of that 3.5 gb fiasco cuz of nvidia.
can i overclock tho?, not really into it but just asking.
what? why only asrock boards?
