Hi guys , i need a computer that can run dota 2 on high settings and with good fps and still be able to stream at the same time . My budget are below $1000.
Can i take Intel Core i5 3570k instead of intel core i7 3770 ?
Yes, and I'd normally recommend it over an i7 any day, because there won't be a difference in gaming between the two, but if you do stream a lot, the hyperthreading (the only thing the i7 has that the i5 doesn't) will help.
However, if you want to stay in budget, the i5 is a great choice - keep in mind, however, that buying the 3570k won't let you overclock unless you ALSO buy a z77 motherboard (I suggest the AsRock z77 Extreme 4) and an aftermarket CPU cooler. (I suggest the Hyper 212 EVO.)
what do you think about this build ? Can this build run on high settings with good fps and stream ?
CPU: Intel Core i5 3570k
Motherboard: Gigabyte Z77X-UD3H
Memory: 8GB Corsair Vengeance 1600MHz DDR3 Low Profile 1.5v
GPU: EVGA GeForce GTX 670 FTW
Case: Antec One Computer Case
Hard Drive: OCZ Vertex 4 128GB SSD
Optical Drive: OEM DVD Drive or OEM Blu Ray Drive
PSU: Corsair TX650 V2
CPU Cooler: Cooler Master Hyper 212 Plus
OS: Windows 7 Home Premium 64 bit
