Need help for buying a suitable PSU for my PC!!!
Chaitanya Patel
i m looking forward to change my PSU please recommend me suitable PSU for following config.
my desktop config is:
processor - AMD FX 8350 4.00ghz
motherboard - Gigabyte GA-78LMT- USB3
cpu socket - AM3+
ram - corsair 8gb vengeance 1600mhz
gpu - amd radeon hd 6670
2 hard drives 500gb & 160gb (might upgrade to 1tb)
1 dvd writer
please suggest PSU under price range of rs.2500-3000($45-50)
i m looking to buy corsair or cooler master units... give ur suggestions please..
thanks.
missed the corsair or cooler master part try a Cooler Master Elite Power 460W they are around 40 bucks just be sure you have all the connections for you vga as im not sure what the 6670 needs off hand
thank you wss_003
