DRUNKCJ :
No I need the space therefore i want to go for a HDD and my HDD model is st1000lm024 .
My specs are I3 5th gen
Ram is 4gb
Intel HD 5500
Drives eventually die. All of them.
You having a drive die after a year is no real indication of a bad brand or model. Just bad luck on that individual drive.
Yours died after a year. The drive that came off the assembly line right before it will last 10 years.
Couple of years ago, I bought 2 WD drives within a couple of weeks.
1 died after 5 weeks, replaced under warranty.
The other, and the replacement, are still going strong.
Seagate, WD, Toshiba....buy one of those, 7200 RPM, in whatever size you need, in your budget.
