Hello there Need help,
Situation: I just bought 2pcs. grid type parabolic antenna (hunter link) and I attached it in the pole with its bolt/screw then I connected its cable to my Huawei B593U-91 modem. I turned on the modem and it has 1 bar with 2g signal (white) . My Pc is connected to modem through lan cable, Now when I turned on the PC and connect to google no intenet loading ? what is the problem?
Huawei B593U-91 modem has its simcard inserted in it, as an Internet Service Provider (Mobily KSA).
Question:
1. Do I need something that will be connected after the 2pcs Grid type parabolic antenna? If yes the what is it?
2. How to know about the frequency operated by a service provider in a specific country?
3. How can I have a 4 or 5 bar signal? What do I need?
Thank you.
Question:
Thank you.
