Need help for fan direction
980322091
20
I am planning to put 4 case fans and 2 liquid CPU cooler fans in my PC. My case is Corsair 750D Airflow Edition. How should I positioning my fans? I was thinking maybe put 3 intake fans at front and bottom, and one exhaust fan at back, two exhaust for CPU cooler?
Something like this
Yes, that's the way I'd do it (except the bottom fan is probably pointless).
Use a piece of paper to confirm air flow.
In general, if the fan blade is CLOSEST on the right side the air is flowing away from you.
Thanks for the reply. What if I remove the bottom fan and install two fans as intake fans at top?
