Need help for hardware problems for gaming
Francesco_4
Commendable
Mar 30, 2016
Hi, I have a problem with my computer, many problems...
These are the spec:
CPU: AMD FX-6300
RAM: 8 GB DDR3 803 Mhz
MOTHERBOARD: ASUSTeK Computer INC. M5A78L-M LX3 (AM3R2)
GPU: 2047 MBNVIDIA GeForce GTX 750 (ASUStek Computer Inc)
MONITOR: S24D300 (1920x1080@50Hz)
HARD DISK: 500GB
The problems started when I suddenly got a lot of frame drops randomly in games, no matter what quality was the graphics on...
I've started thinking about an upgrade for my pc, but searching for better GPU's and CPU's I noticed that my actual build, speaking of GPU and CPU only, is not bad at all, and runs gta V at high with no critical frame drops...
I've never been able to play such games at such high graphic settings!
I already tryied to OC my cpu and gpu long ago, but I've never saw such an improvement in gaming...
So tell me what should I do? Is there something that needs to be upgraded? Or just fixed?
(I'm actually playing games such Black Desert Online and I still cannot play it on 60 fps having textures and effects on "low" too)
Thank you guys and I'll appreciate any sort of help!
GTX 970 will be perfect for 1080p gaming,but u need a min PSU that can supply 500w so you should check your own power supply if you are thinking to getting the gpu.To be quite honest the R9 390 is ouperforming the GTX 970 and since it has more memory 8GB you can play even at 1440p but you will need a beefier PSU like 650w or more.
First if you are not runing the latest drivers dowload them from the nvidia website www.nvidia.com/drivers .Second if you still have problems try reinstalling Windows,and if that doesnt work its probably your gpu its too weak for the games you want to play.I have no idea how you are ruining GTA V on high with a gtx 750 on 1080p.The gtx 750 is an entry gpu and i dont think its ment for 1080p.
I use Nvidia Geforce experience so, I cannot mistake the drivers. Just yesterday I formatted my pc, so I don't think is that the problem... I haven't ever run GTA V on my pc, I simply saw some videos where people are testing their gpu and got almost 40-50 fps avg all high setting
What do you think is better? I'm thinking about a GTX 970
