Need help for monitor!
Oct 10, 2018
16
Hi, I juste bought 2 g27c2 to have a triple monitor setup. however, i only have 2 DP, 2 HDMI, and 1 DVI ports. I was wondering if I plug my main monitor into my DVI, and the two others in DP, will I be abble tol use them all at 144hz? thanks alot^^
As I said it probably will work for three 144 Hz monitors. The dual link DVI-D and the DisplayPort on that card each will support 144 Hz displays.
Thank you for you answer, but I meant between 1 monitor 1920x1080 vs 3
monitors 1920x1080. And By the way, should I consider buying a DVI Dual Link cable, or a Hdmi 2.0 to Displayport 1.2 adapter and plug my third monitor into it.
thanks again^^
That is what I was referring to. I wouldn't expect a lot of impact on the FPS for three monitors, but there will be some. I would leave HDMI out f it. I would use only DisplayPort or dual link DVI-D monitor cables.
MERGED QUESTION
Question from anthony_kane : "Dual Link DVI vs HDMI 2.0 to Displayport 1.2"
thank you^^
