Hey,
I wanted to know If there are any better cpu cooler that will fit in my case. My case is a http://www.sharkoon.com/?q=en/node/1902 And as you can see it says: Max. height CPU cooler 15.5 cm So The NH-D14 Is 16 cm And so will not fit. Are there any others that will fit My Cpu is a Intel I5 4670K And I'm going to overclock it
Thanks allot,
Thanks allot,
