Need help for my cpu select 4590 or 4690
senpaikiller9
115
So in germany the price difference is almost 30€ and the difference between the CPUs is the 0.2 ghz.
So is it really worth the 30€ just for that? I plan to do just gaming and I want for my PC to last 4 years my gpu is msi gtx 970. I dont mind going to medium settings but for now I want to have high-max 60 fps. Thanks in advance for your answers!
4460 is avtually the best buy unless you want to be able to overclock. The NZXT S340, Cooler Master N200, Corsair 200R or Silverstone S11are all good budget cases.
Either is fine, theres not much of a difference between the two just the 4690 has a higher clock speed, if you're not going to OC go with the 4590.
In my opinion if the only difference in cpus is a slightly better clock speed it is only worth 5-10€ more if it is over that, it is not worth the extra money. So for that much of a difference between 4590 and 4690 the 4590 is much better value with almost identical performance.
