Hello,
I'm building my first PC on my own, and i would like som help from you guys.
The build: https://pcpartpicker.com/list/TJCfNQ
I'm using the "EVGA SuperNOVA 1000 P2, 80+ PLATINUM 1000W" - but i coudn't find it on the build website i used.
The PC is going to be used for heavy edits with effects in PremierPro , After Effects, Photoshop, and some gaming on the side - but mainly editing.
Are the components a good choice for my needs?
And last, i'm worried that the components can't fit in the case i chose. Do any of you guys have any expertise about the Cooler Master MasterBox MB530P?
Thank you so much
Thank you so much
