Need help for my new rig.
xperiapromk16i
Hello there,
I planned for this AMD build. It is good enough? or should i go for Intel build?My budget is around MYR2500 or $700.
I'm going to use it for editing in Ai and Ps plus some gaming such as BF3,4,Thief,Dota 2 and so on.
CPU: AMD A10-7700K
MOBO: ASrock FM2A88X Extreme6+ FM2+
RAM: GSkill RipjawsX Blue 2x4GB DDR3 2400mhz
HDD: Seagate 1TB Baracuda HDD
GPU: Sapphire R7 250X 2GB DDR5
PSU: Xigmatek Tauro 500W PSU (80+ Bronze)
Chasis: Aerocool Xpredator Evil Black
ODD: liteon 24x Sata DVDRW
Cooler: Scythe Katana 4
Monitor : Dell 23" S2340L(Full HD IPS)
I'm new in here. Could you guys lend me a hand in determine the best parts?
Thanks and hoping for some reply :)
Well I would consider:
* The FX 6300 if you can afford it over the A10-7700k, because it will be a bit better overall. You have a bit weak 250x GPU, so you could consider the Athlon x4 750k/760k (no integrated GPU) and use that extra $ to buy a 260/260x/270 (whichever fits the budget).
* Also I would drop your RAM speed down to 1600/1866 mHz, since your not going to be using the iGPU of the A10 or x4 750k/760k. Try to get RAM that has LOW HEAT spreaders, so if you add an aftermarket CPU/HSF, you won't have any clearance issues with the RAM and the CPU/HSF.
* The rest of the build doesn't look too bad. I'm not sure about the PSU, but it is 80+ Bronze, so that would usually mean that it could be built fairly well.
* IPS panel is a...
* IPS panel is a good option to keep, since they produce good colors and is probably better for content creation in Ps and Ai.
Example of FX 6300 build (not sure what is available where your at):
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($109.99 @ NCIX US)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($106.99 @ NCIX US)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($68.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($56.99 @ NCIX US)
Video Card: Sapphire Radeon R7 260X 2GB Video Card ($104.40 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($44.99 @ NCIX US)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($14.99 @ Newegg)
Monitor: Acer G237HLbi 60Hz 23.0" Monitor ($129.99 @ Newegg)
Total: $677.32
(Generated by PCPartPicker 2014-05-09 06:18 EDT-0400)
FM2+ build option:
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor ($84.74 @ Amazon)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard ($77.24 @ Amazon)
Total: $622.32
(Generated by PCPartPicker 2014-05-09 06:19 EDT-0400)
