good morning! I am planning to upgrade my desktop dell dimension 9100 to be at least average for gaming, it still works fine even i replace the OS (from xp to win 7) i also found in this thread that there are so many things to pay attenion for this unit to upgrade, i'll put the notes after the previous specs i have, hope you guys can help me....
Mainboard: Dell Dimenion 9100 Series model: 0x8582 chipset i945p
don't need to replace, i found in this thread that the board is the only one that fits the design in the back panel of the CSU Case
CPU: Intel Pentium 4 640 3.2 ghz Prescott ( upgrade to intel pentium d 945/950/960 or the least pentium d 840)
i found in this site that the mobo doesn't like much the core 2 duo processor to be installed (there are few who succeed but most of it fails) so i switch to pentium d 945/950/960, people here said that i just need to upgrade my BIOS from A01 to A03 and i succesfully did it, but i want to make sure, does this d 945/950/960 processor really works on my mobo eventhough the max L2 cache of my mobo is 2 mb and 945/950/960 have L2 cache of 4 mb or it will just burn my mobo?, then i came up with the least pentium d 840 which have 2mb of L2 Cache but only 3.2 ghz frequency 🙁.... if there's someone out there that succesfully run the dimension 9100 with pentium d 945/950/960 please guaranteed me, i really want that 3.4 ghz and above to be installed.
Video Card: ATI Radeon x1300/1550 series (upgrade to nvidia 9800 gt)
i found in dell's forum that someone is using 9800 gt with the same type as my system, I'm not so sure of this because i was thinking if this GPU speed can came up with the mobo and the processor or sooner it will burn my mobo? if its really work then i will buy this 9800 gt, the reason i don't want to try for other higher gpu because other hardawre doen't fit inside (might hit the processor heatsink and fan) which makes the upgrades for gpu very limited that's why i want the best one that fits and run with my system efficiently. if you have some other suggestion for other video cards that are tested with same type of my dimension 9100 please just inform me...
Memory Card: 2 pieces of samsung ddr2 533 512 mb (1gb) max upgrade is 4 gb and supports 400/533/667 bus speeds and have four slots (each one have 1 gb max).
this one frustrates me, i put a kingston ddr2 667 2GB and it works, so right now im using 3gb of mem card (2 pieces samsung ddr2 533 512mb and 1 piece kingston ddr2 667 2gb) how come my 2 gb kingston works in a 1 slot with a max of 1 gb? is it really okay or it will destroy my mem slot or my mobo will get burned by it? if it's okay then i will buy another kingston ddr2 667 1gb or 2gb, regarding with this, i heard that a 32 bit OS doesn't support more than 4 GB of RAM so im really confuse if i will max the 4gb RAM upgrade or just 3 gb?, im not planning to upgrade the OS to 64 bit because dimension 9100 might crash in such OS bit, not so sure of this.....
below are not needed to upgrade:
1 DVD-RW
1 usb keyboard and 1 usb mouse
1 standard desktop speaker
below are the list of hardware i remove from my desktop because i know it consume wattage and needed volts from my PSU:
802.11g wireless pci adapter(dont need wifi connection. its wire connected)
another pci audio hardware (don't need im satisfied with the standard)
pci modem for fax (really don't need)
Power supply: original DELL 375 Watts (not sure if i need to upgrade this also with those upgrades above)
the above upgrades range between 40-50 usd, so its cheap, i don't want to replace the mainboard and the heatsink because its really good (i think the heatsink is one of the key that my dimension still works very fine even for 8 years 😀)
thats it.... i really need help for this upgrade.... I am hoping for the best possible upgrade to have in dell dimension 9100 series....Thank You very much in advance!
1 DVD-RW
