Exly786 Sep 3, 2020 2 0 10 Sep 3, 2020 #1 Hi I have i7 8th gen 8900,A 750 watt corsair psu,and a Gigabyte H370 AORUS GAMING 3 WIFI 8th Gen Motherboard can my Motherboard and cpu handle a 3070?I can upgrade my PSU if needed
Solution theonerm2 Sep 3, 2020 You mean i7 8700 right? Your system is good to go. Even for the RTX 3080.
Lutfij Titan Moderator Oct 7, 2009 61,597 6,912 178,440 Sep 3, 2020 #2 Model for your Corsair PSU? You Will most defitnitely be able to drop in that GPU. Upvote 0 Downvote
Exly786 Sep 3, 2020 2 0 10 Sep 3, 2020 #3 I have RM 750x But IF needed I might get a 1000w one Upvote 0 Downvote
theonerm2 Splendid Dec 28, 2009 4,114 81 26,740 Sep 3, 2020 Solution #4 You mean i7 8700 right? Your system is good to go. Even for the RTX 3080. Upvote 0 Downvote Solution
