Question Need help for PC/PS4 audio
Loki_TSO
21
So, I recently bought a PS4 Pro and I'd like to be able to use my PC speakers, wich are plugged in via audio jack on my PC. Since the PS4 only has an Optical port, I'm wondering what kind of audio hub I should buy so I can easily switch between my PC and PS4 audio. So I'm basically looking for something that can plug my speaker's jack and split it between optical and jack and just choose the channel.
Thank you for your help!
There's not really anything cheap enough and practical enough for what you want.
Only thing I can think of is a sound center unit that takes optical input or HDMI input and can output to different connections, but that's expensive and meant for you to connect a sound system at which point you might as well just get an affordable sound bar setup.
You can use your PC for it though using PS4 Remote Play to stream the video and audio, and can just downsize the window so it's not in the way when using PC.
Just need to plug the PS4 controller into PC using USB or connect using Bluetooth to control games on TV.
