Hello guys, could anyone help me to answer those questions, please?
Thanks 😉
1. Name 2 TCP/IP command line tools that can be used for troubleshooting and explain how you would use each one to help you determine your problem?
2. Describe 4 settings that can be configured through a Password Policy.
3. What is the difference between working in the Command Prompt Window and working in PowerShell?
4. Describe how a firewall filters incoming traffic to make your network more secure.
5. Explain the differences between a Workgroup and a Domain, and describe when you might use each.
6. Explain virtual memory and paging.
7. What are the most common causes of boot failure and what steps should be taken to get the server running again?
8. Explain the difference between NTFS and Shared Permissions.
9. Describe the 4 settings you must configure if you are manually configuring TCP/IP on a workstation that must connect to the Internet.
10. List and describe 4 of the built-in Local groups on a Windows Member Server.
11. Explain how a DNS Server works to resolve names for client computers. What happens if the DNS Server does not know the answer for the client computer?
12. Describe what happens during Authorization when a user tries to access a protected resource.
Thanks 😉
